7010 Engine
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: 7010 Engine
    Posted: 14 Jun 2011 at 7:54pm
I looked at a 7010 tonight, the tag on the side of the engine had a 2900 on it. Would that be a 301 or a 426.
Brian
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Russ SCPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2011 at 8:05pm
301 CID with a turbo, nice little engine, good power and reasonable fuel economy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2011 at 8:05pm
301 ; 7010+7020,s had 301,s - 7030 on up had the 426
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2011 at 8:56pm
What #s would a 426 have on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2011 at 8:58pm
It is a scrap tractor, needs a crank. Thinking I can part it out and make enough to rebuild the mptor for a future pulling project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2011 at 9:00pm
3500-3700-3750-670T-670I-670HI
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2011 at 10:23pm
Thanks, Does any one on here pull one of these motors. How much HP can you get out of them. I know that cash will get you all th HP you want, but what about a good rebuild with some head porting and better turbo and pump tinkering.
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2011 at 9:23am
It is the 6 cyl version of the 6080 engine, same pistons. You can get a lot of power out of the 301, the 7010 drive train is too heavy to pull. Need 185 or 190xt drive train. Go to you tube and search ABAC Cracker Jack and you can see power. ABAC is college in Tifton, Ga. I helped build cracker jack when I when to school there.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2011 at 10:37am
Don't forget about the non turboed 3400 426.
Wink
I am a Russian Bot
