7000 transmission ?
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Topic: 7000 transmission ?
    Posted: 30 May 2016 at 12:17pm
My 190 xt jumps out of 7/8 th gear under load and 5/6 coasting down hill. Play in the rear end too as well as all the issues one might expect to find on a 50 year old tractor. This is getting worse as time goes along. Will an earlier 7000 with the red frame and floor shift have the same issues? It is ten years newer!
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 12:55pm
Mine has 8000 + hrs and doesn't do that.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 4:34pm
I have heard the gear jumping problem was corrected on the 7000.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 9:44pm
Age is not the issue.  Who USED (abused) the tractor is the issue!
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 9:58pm
7000 had gears that had shifting lugs with a degree or two positive  so as to prevent this . The down side was if the clutch had a drag on it,,, it was hard to get
OUT of gear...  190 gear jump was due to 1 abusive shift ing - grinding the gears, over power causing the pinion shaft to loosen up , improper engagement from the factory where as the gears never really shifted all the way in from day one.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 10:08pm
7000 had a transmission brake which helped except for reverse. People would pull them out of park into reverse befor gears stop turning grinding the teeth off of reverse gears.  MACK
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 5:17am
Thanks for the info.
This page was generated in 0.091 seconds.
