7000 rear hydraulic pressure
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Topic: 7000 rear hydraulic pressure
    Posted: 14 Aug 2017 at 6:07pm
I only have 700 lbs at idle. At 1200 rpm the gauge shows 1200 lbs. At 1800 rpm its 2250. Is this low reading at lower rpm normal.  Tim
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2017 at 9:47pm
Sounds about right. Where are you checking it?     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 4:58am
Right at both rear outlets. Tim
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 5:27am
If you wanna install a loader you will need to shim the pump.  good AGCO dealer will walk you thru the process.   I'd call 2250lb as normal.
AC from the start of my families farming career till the end!
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 11:23am
I'd like to hear more peoples' experience with this, as my 7000 is much like this as well. It makes it a bit annoying bc not much will operate at idle. My fords all put out full pressure with a gear pump at idle. I'm thinking my pump might be a little on the worn out side, I've adjusted the relief pressure at the remote valves to 2300 psi, but I have to be close to 2000 rpms to get that. Anyone have one with a new pump or remember from when they were new? Do these pumps turn too slow at idle to be very efficient?
Hurst
Edited by Hurst - 15 Aug 2017 at 11:25am
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 6:18am
I haven't turned mine up yet Hurst. I thought the problem was unique to just my tractor.  Tim
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 6:44am
The pump has been rebuilt on my 7000 and still the same as yours, very low pressure and flow at low rpm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 7:14am
That's the way it is. The priority valve sees to it that the power steering works good at slow speeds and as a result, the lift system isn't very good. Get over it or get a 7010 or bigger.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 6:40pm
Did they change much between the 200 and 7000? Or do they act the same as well?
Hurst
5800 Hours
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 8:13pm
My 190XT III is the same way, to get good pressure you need to rev the engine some.  My D21 II will give full hydraulic pressure at an idle.  I don't remember if the 200 I ran for a farmer had good pressure at an idle or not, most of its time was spent on a feed mill and not running hydraulics.  The 190 doesn't do bad once you get to around 1200-1400 rpm, but for full pressure you usually need at least 1500 rpm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 7:18am
Very late XT's and 200's had the same hyd pump which are similar (but not the same) as a 7000.
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 10:10pm
I had to put a new pump on my 7000(black belly), now the power steering works better than it did for quite a while but the PTO disengages when I shift the power shift. Kind of annoying. Maybe your pump is getting tired?
WD,D15,190XT,7000,8010x2,7060,8070
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2017 at 6:58am
Mine also disengages when I shift the powershift sometimes, but I'm not sure my pump isn't a little tired. I think the spring in the spool can be cut down a little to help with that problem, but haven't tried it yet.
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2017 at 7:23am
Some black belly 7000's had an occasional issue with the PTO lever jump-out and there may have been an orifice fix for it. I cut off the spring if I remember right....didn't have only 1 or 2 of those models to contend with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2017 at 7:48pm
Thank you guys for the information. I was talking to a guy at the GOTO today. Who mentioned I could swap the relief valve from the traction booster, just to make sure the lift valve wasn't sticking. Tim
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2017 at 2:45pm
The draft control outlet line can be tee'd into the flow to the remote/3 point - draft will now not work well but.... Adds about 3 gpm to the flow.
