7000 A/C leaks
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Topic: 7000 A/C leaks
    Posted: 03 May 2010 at 1:30pm
I got a call from my Dad this PM and he called to tell me that the A/C in my 7000 black belly was not very cold when he used it for the first time this summer.  I went though the entire system 2 years ago and replaced all the o rings, hoses, and the expansion valve.  I had a bad hose in the system.  It holds a charge through the summer pretty well as far as I can tell (I never added any last summer), but every winter it loses the charge.  It has the original A6 compressor on it.  I have run both 134a and the hydrocarbon refrigerants in the system, and both leak out about the same.  Is this just normal for an older A6 compressor, or should I be looking for a leak in the 134 adaptor fittings on the compressor?  I have had these in mind as being the culprits for a while, but I haven't changed them.  I have done soap and water over the connections and found no bubbling.  Maybe someone on here has had a similar experience?
Hurst
1979 Allis Chalmers 7000
5800 Hours
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 1:48pm
we've just came to the conclusion that they're almost always going to leak out during the winter.
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 5:05pm
Might be the same thief stealing Eldon's air out of the tires...sure gets around going from WA to KY, LOL!  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 5:20pm
Did you install barrier hoses or standard R12 hoses? The standard hoses will leak with R-134a.
Onslowe in Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Onslowe in Mo Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 5:23pm
The A6 compressor isn't inherently leak prone.  Some systems just have a weak spot or two that is hard to find, even with a halogen leak detector.  On a hard to find leak, I think using UV dye in the system and then checking for leaks is the only way to find it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 6:30pm
My brother had a slow leak in his Caravan and the mechanic said it would cost $700 to fix because there was a leak up under the dash and in the back. He went to Wallyworld and bought some refrigerant with a sealer included and puts one can in every year about this time. Much cheaper and easier than gutting the inside of the vehicle and paying out the nose for the repair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 6:47pm
The A-6 is one of the easiest compressors to replace a shaft seal in if thats where it's leaking. Tracer dye is what you need. Dye will find the leaks too small for a halogen detector to find. Just need a black light and amber colored glasses. Ford and GM both started putting dye in the systems from the factory about 2002. That's a God send for warranty or otherwise A/C work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 7:29pm
There is some oil residue I remember last time I was home right above the compressor pulley, but it seemed to be pretty well crusted over with dead bug guts.  I read that A6's were pretty bad about having a little oil leak out of the shaft seal with the noninterface ceramic seals they used.  I guess I need to try the UV dye first before throwing parts at the compressor/AC system.  The replacement hoses were barrier hoses rated for 134.
Hurst
5800 Hours
