7000/8000 Powershift detents adjustment |
slowzuki
Topic: 7000/8000 Powershift detents adjustmentPosted: 16 Jun 2017 at 2:05pm |
Hi I have an AC 7010 PS, I've searched a bit and don't see this addressed exactly.
First on the valve body is engaged when you are on the detent between neutral and 1st. Second is the same way. Third sometimes works, doesn't go in and needs a wiggle or nudge. Fourth and fifth work in the proper location but you can't access 6th as it hits the end of the slot. I've checked the arm for tightness thats fine, clutch comes up all the way. I'm curious how the detents can get out of position to the valve body porting?
MACK
Thanks(1)
Posted: 16 Jun 2017 at 2:18pm |
Linkage inside valve body broke. MACK
