7000/8000 loader valve
acnh210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Topic: 7000/8000 loader valve
    Posted: 30 Jul 2012 at 8:03am
I have installed a seperate loader valve on an 8050. It is load sensing closed center. I did this verses the open center so the pump wouldn't run all the time and tie up a remote. However when you try to use the factory remotes you have to move the joystick at the same time to get it to work. I simply tee'd off right off the pump with the thought that was closed center so this would work. Obviously I'm wrong. Any help would be appreciated.
Thanks
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 7:57pm
The new valve has to be a load sensing valve.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 8:07pm
When you stroke the new installed valve to send the oil to work, your not getting any fluid due to the oil flow is still going through the primary valve. So it's an open center valve right? I'm not familiar with the 7 & 8 series tractors so I'm just guessing.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 8:17pm
From what I have learned so far. The pilot oil which is always flowing, from the load sense line to the drain line until a lever is pulled, then pressure is the built up as needed. I have it tee'd right now so the oil simply goes through the other valve and pressure is not built up. I understand I need the check valve but can't figure out which one or where to get it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 9:39pm
Load sensing valves are closed center.
There is no pilot pressure. The main pump is at low pressure until a valve is activated. Pressure the builds and goes to the load sense line and strokes the pump to build pressure. The valves have check valves in the load sense line already.
Like I stated in the other post, the  load sense lines for each valve have to be tee'd together. The same goes for the pressure. The added valve has to be a load sensing/closed center valve. Nothing else will work.
This page was generated in 0.081 seconds.
