7 ft. cutter bar on b c mower |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4072 |
Topic: 7 ft. cutter bar on b c mowerPosted: 12 Jan 2022 at 10:22am |
can this mower handle a seven foot cutter bar off of a 82 r or maybe a 501 ford mower
Brian G. NY
Posted: 12 Jan 2022 at 10:51am |
It doesn't take much to power a properly adjusted sickle bar with sharp knives and ledger plates. The No. 5 mower for the B and C tractors could be had with a 5, 6 or 7 ft cut bar. Having a seven foot bar on a small tractor requires some thought if used on side hills. Raising any bar, let alone one that long with the bar on the down side of a hill can get you in trouble. I mention this because in my neck of the woods, we have to deal with hills a lot.
Mowing with a seven foot bar as opposed to a five foot bar will increase productivity a whole lot; like as much as 40% if you can mow at the same speed.
Joined: 11 Sep 2009 Location: illinois Points: 90808 |
Posted: 12 Jan 2022 at 12:26pm |
I use a 7 ft on a B to cut along the road ways.. If the boy lets the weeds/ grass grow up to 4-5 ft on the farm , i sometimes use the sickle to cut it down instead of the bush hog... Brian is right, that side of the tractor is HEAVY.. Dont get on any type of side hill... I have thought about adding 100 pounds of weight off to the opposite side..... The left rear tire can get a little LIGHT if you run the right side too far off the side of the road.
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Thanks(1)
Posted: 16 Jan 2022 at 10:07am |
Please listen carefully to the comments above. The B-C mower will mount a 7' bar with no problem. We found problems in the side draft that pulled the tractor to the right when in heavy mowing. Also, as stated above be EXTREMELY CAREFUL when working on hillsides with a 7' bar. Just too heavy for a B-C tractor.
In fact, we NEVER put a 7' bar on the B-C mower. Just too much to safely handle Good Luck! Bill Long
HudCo
Posted: 16 Jan 2022 at 6:31pm |
we grew up on ground that when the bales came out of the baler they rolled half way to the bottom of the field, and the swather allways trying to pull the back of the tractor down hill , four wheel hay wagons were a no no they were way to scary could only load hay on trailers. but this is all pretty flat ground now and it has calcuim in the tires. my concern is if the mower frame and pitman can handle it , and can the lift parts handle the weight , will it take all of my 168 lbs. to pull on the lever this is the new toy so if i am going to use it i have to get somthing done
Posted: 17 Jan 2022 at 9:29am |
I built a ROD out of 3/4 inch water pipe to run from the "lift" , under the seat to the back end... have a pivot point and use the small B hydraulic cylinder to "LIFT" .... Yea, its a pain to do it manually... Should be a spring at the front to "help".
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 17 Jan 2022 at 1:41pm |
I have some of those standard balance springs for the B/C mowers. I also have one that is a much stronger spring of the same dimensions except for a much larger wire diameter. There is a factory part for the hydraulic lift connection.
HudCo
Posted: 17 Jan 2022 at 3:00pm |
i got it to lift pretty smooth and easy with the 60"cutter bar. no adjustment left in the spring thats on. it i seen in the parts book a hydralic lift option i do not have any of the rockshaft parts but ido have the two little lift cyllinders i have really been looking at fabing up a three point hitch
