66 all crop combine |
Mikes5785
Topic: 66 all crop combinePosted: 12 Aug 2018 at 2:31am |
Well I’ve been puttering around with my 66 allcrop everything spins fairly freely, except the grain elevator to the bin. I peeled what’s left of the bottom elevator door open and found the elevator full of compost. I tried to dig it out and am not sure how much I got out or how much is still in the elevator. It looks like at least some of the cups are gone or severely rotted/rusted away. I’m wondering the easiest way to R&R the elevator cups & chain. Wether to remove the top axle and let it drop thru to the bottom or try to remove it from the top
Thanks Mike |
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2043 |
Posted: 12 Aug 2018 at 9:37am |
I have chain and cups if you need them. I would remove from the top.
combinechris
Joined: 20 Jul 2015 Location: wittenberg,Wi. Points: 424 |
Posted: 12 Aug 2018 at 8:33pm |
No remove from the bottom, connect the new chain to the old one and install the new one as you spin the old one out. Connect the chain at the bottom.
35 combines and 15 forage harvesters. mostly allis combines and equipment.WTB 2 row cornhead for a 90
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 12 Aug 2018 at 9:45pm |
I see merit in both Lon and Chris's method. Which one I would choose depends on the situation. Is all the trash out? If not, I'd be poking a running garden hose down the top trying to get it cleaned out. Are the chain links free or rusted together? If they are free, I'd try doing as Chris says. If they are rusted together, I'd try pulling it out the top as Lon says.
shameless dude
Posted: 12 Aug 2018 at 10:25pm |
do as Chris says, cuz if the chain slips from your fingers, you know what you'll be trying to dig out then!
Mikes5785
Posted: 13 Aug 2018 at 11:22pm |
Further details, the elevator is cleared out, the top chain gear is loose and will move within the amount of the slack in the chain. Trying PB Blaster on the bottom bearing/gears trying to make things moveable
Mike |
CrestonM
Posted: 14 Aug 2018 at 9:56am |
I'd heat it up if it was me. I've done that on stubborn stuck parts when dismantling parts machines, and it works great.
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 14 Aug 2018 at 7:57pm |
Out the bottom would work great if you tie rope to the top and cut the chain. Takes a rope on each end and tie it off. If you don't, I guarantee you it will fall and you will wonder where your head was. LOL
Mikes5785
Posted: 21 Aug 2018 at 3:26pm |
There’s a kink in the lower bearing sheet metal bearing panel. Is it possible to either remove that panel or r&r the clean grain elevator without disassembling most of the combine. It appears that there are 2 sets of bolts & clamps holding it in place and the mechanics of the feed to the grain elevator.
Also I need some of the clean out doors is there somewhere they might be available from Thanks Mike Edited by Mikes5785 - 21 Aug 2018 at 3:42pm |
Brian Jasper co. Ia
Posted: 21 Aug 2018 at 6:08pm |
Tom Yaz used to have or make many parts for the All Crop. Google Yaz Allcrop
MACK
Posted: 21 Aug 2018 at 10:19pm |
Disconnect chain at bottom, go to top and pull chain up. New chain, drop in both sides from top. MACK
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34430 |
Posted: 22 Aug 2018 at 12:40am |
and make sure you got the chain in the right way too.
wlambs
Posted: 22 Aug 2018 at 12:10pm |
tom's website is all crop harvester .com. you can get most parts you need from tom.
Mikes5785
Posted: 23 Aug 2018 at 8:16pm |
A development on the grain elevator on my 66 all crop combine, started to R&R the lower cog/gear shaft and found the rear brass bearing seized to the cog/gear shaft. Removing the 3 bolts holding the bearing housing to the elevator and A bit of heat and a bit of judicious persuasion with a hammer & punch got the bearing housing removed.
The rest of the elevator seems to be free and movable More adventures to follow Thanks Mike |
