65' 190xt Front Wheel Hub Removal
whizone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whizone Quote  Post ReplyReply Direct Link To This Post Topic: 65' 190xt Front Wheel Hub Removal
    Posted: 24 May 2020 at 6:55pm
All, my 65' 190xt front wheel bearings have worn out and need to be replaced. Can someone tell me how to remove the wheel hub's cap to get to the big nut for removal. Does the cap screw off or is it just pressed in? I noticed it has sides like a nut and didn't know if I needed a huge wrench or if I could just drive it off?  Also is there anyplace online I can get a set of wheel bearings ect for it?  Thanks.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 7:14pm
Seems like our '68 models' caps just press in Ermm ,dad was the last to mess with them. Can you look up a part # off of the Parts Book Site and google the # ? Hopefully your spindle is still in good shape Big smile.
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 7:15pm
If dust cap looks like a big nut it should unscrew . If the dust cap does not look like a big nut it should pry off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 7:18pm
Originally posted by FREEDGUY FREEDGUY wrote:
Seems like our '68 models' caps just press in Ermm ,dad was the last to mess with them. Can you look up a part # off of the Parts Book Site and google the # for the bearings ? Hopefully your spindle is still in good shape Big smile.
Like I said, dad messed with the 190 LOL!!! It's got the "nut" look. I looked after all of the other wheel bearings LOL
Edited by FREEDGUY - 24 May 2020 at 7:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote whizone Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 7:35pm
I will attempt to unscrew it first and hopefully it comes off.  I think the spindles should be ok but you never know until you look. Thanks much for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 8:15pm
You can use a big pipe wrench it you dont have a cresent that big... Look close and you can see a small crack between the cap and the hub.... tap with a hammer on that area of the cap to loosen up the rusted threads if the cap dont come off easy.
ksbowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 8:34pm
My 65' 190 screw on. I don't remember if one was left hand thread and one is right hand or if both are right hand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 8:40pm
both are right hand... counter clockwise to remove.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whizone Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 9:02pm
I will lubricate it well and grab the pipe wrench as I dont have a crescent that large. Hopefully the rust hasn't taken completely over yet. Do you guys know if you can get the bearings from an auto parts store like Oreilly's or NAPA ? I really would like to get these fixed soon. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 7:44am
NAPA should be able to get them. If you have a Motion Industries close by, I would use them. You can google Motion Ind and find the closest store near you.
AMDG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMDG Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 6:36am
Just did both sides on 69XT. Used pipe wrench. Ended up replacing one outer bearing. After soaking in gas to clean up it totally fell apart in hand. Replaced from agco.
Ad Majorem Dei Gloriam
This page was generated in 0.158 seconds.
