620 Mower deck removal
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: 620 Mower deck removal
    Posted: 27 Aug 2011 at 9:05pm
I'm looking at taking the belly mower off of my 620 to check the arbors and blades.  After unhooking the cables and front pins, what is the best way to get it out from under the tractor?  Looks like it could be a tight fit pulling it out from the side between the front and rear tires.
What is the best (quickest and easiest) way to accomplish this task?
Many thanks!
Dale H. ECIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2011 at 9:16pm
I have taken the decks off both my 620 and 720 mowers several times, turn your front wheels to the left and pull the deck out on the right side, tight fit but it will come.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2011 at 12:44am
We always just throw a couple of 2x4"s between the front wheels, and the mower deck, and back the tractor over the deck.  This will require taking off the black front mount, but that is only 4 more pins.  It sure beats dragging the deck out from underneigth, and back under later.
Still in use:
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2011 at 6:10am
i wrap a small chain around my waist and hook somwhere on deck and pull ,it s so heavy i do have to jerk on it i think it is like 280lbs,but in the book i t says to back over it but it always slides on me that why i do it my way
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2011 at 8:21am
I set it down on my creeper and lift the front with either the shop crane or the d15 bucket.then I just roll it out from underneith.
Nate (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nate (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2011 at 8:59am
We turn the wheels to the left but we put a thin board under the rollers so it slides easier.  We take it off to clean after every mow for about 7 years now and have had no problems this way.
This page was generated in 0.251 seconds.
