616 -620 fuel pump troubles? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10876 |
Topic: 616 -620 fuel pump troubles?Posted: 26 Apr 2011 at 8:43am |
Are there any spacers required under the mechanical fuel pump? Is there a good alternative to factory fuel pump? One that will not flood carb out? Is there a vacumn port that would run a new style vacumn pump?Any help appreciated. Tracy Martin
Larry Miller
Posted: 26 Apr 2011 at 11:19am |
Tracy - I have put 3 fuel pumps on these tractors. I used a Facet Automotive electronic fuel pump. Just under $50. Be sure to get the low pressure - (3 to 5 lbs I think). I mounted it high just above the oil cooler with a bracket under the tank strap. Have had no problem with flooding yet. I left the old pump in place and plugged the fuel lines. The instructions suggest tapping electrical into a low oil pressure switch so the pump will stop when the engine stops. I just put a line on the coil and it runs when key is on. Not sure that is a good idea but what I did.
Joe O said there were kits for the old pumps but I have not found or priced them. |
I used to be young and stupid, now I am not young anymore.
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 26 Apr 2011 at 12:12pm |
I think the source was Cummins Engines of Springfield or Kansas City, have ordered parts from both.
Tracy Martin TN
Posted: 26 Apr 2011 at 1:05pm |
I have the weakest Facet on it.Even have a pressure regulator too. Can't depend on it not over flooding while running. I wish there was a better alternative than the mechanical nightmare pump. I think I might put a TEE in the line and return it back to the tank. That should leesen the likelyhood of flooding. Thanks for the responses. Any help always appreciated. Tracy Martin
Larry Miller
Posted: 26 Apr 2011 at 1:36pm |
Tracy - My tractors have that T just before the carb. I think original equip. Anyway, yes you would need that to relieve pressure so the float would shut off before flooding the carb.
By the way - they don't run well if you reverse the lines from the tank. Don't ask how I know this. I also found that the load needle may need adjustment now that you have a lot of fuel - Mine was set way rich maybe because not enough fuel as pump was failing. ?? It ran OK but under load it would blow black smoke and almost quit.
Tracy Martin TN
Posted: 26 Apr 2011 at 7:31pm |
I wonder if one of the electric pumps made for a Onan generator would work without modifications? Where is D17 Dave when you need him? He is the guru of these tractors.I bet he has seen every setup imaginable. Tracy Martin
JoeO(CMO)
Posted: 26 Apr 2011 at 7:42pm |
I found the box for the fuel pump kit I used on 720-...Onan #0149-0526
Toscani NE SD
Joined: 21 Jan 2011 Location: Milbank S.D. Points: 369 |
Posted: 28 Apr 2011 at 7:38pm |
i don't think u have a fuel pump problem,it sounds like the carb needs leaning out,my 620 is very fussy on starting and will choke off if you don't do it right,i always thought they had to weak spark,and considered adding a MSD blaster ignition module,but i don't know enough that i won't fry everything.
