6080 hydraulic flow control??
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: 6080 hydraulic flow control??
    Posted: 18 Apr 2017 at 11:59pm
I will be using the 6080 to run a hydro-push manure spreader tomorrow. I see in the spreader manual that the hydraulic flow rate should be no more than 6.8 gpm or it may cause a pressure drop. According to tractor data, the tractor is rated at 11.4 gpm. I can't see in the manual where this can be adjusted....will this be a problem?
spreader we will be using:
http://www.pikrite.com/wp-content/uploads/2013/02/HR250.pdf
ALLIS EXPRESS!
This year:
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 4:05pm
At full rpm it is at 11.4 gpm. Run it at 2/3 throttle or less would meet the spec.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 9:31pm
Couldn't run it at 3/4 throttle as I needed all the power I had. That spreader was a brute, no way a 60 hp tractor would of pulled it in those soil conditions. Checked the hydraulic filter after 3 loads and it was just warm, so I think everything was fine. 5 hours to spread 100+ tons...slow part was the little Kubota loading me. He did have to pull me out twice, tho. I was surprised, thought we were going to have to find a bigger tractor the first time....
ALLIS EXPRESS!
This year:
