6080 hydraulic flow control??
Message Reverse Sort Order
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: 6080 hydraulic flow control??
    Posted: 19 Apr 2017 at 9:31pm
Couldn't run it at 3/4 throttle as I needed all the power I had. That spreader was a brute, no way a 60 hp tractor would of pulled it in those soil conditions. Checked the hydraulic filter after 3 loads and it was just warm, so I think everything was fine. 5 hours to spread 100+ tons...slow part was the little Kubota loading me. He did have to pull me out twice, tho. I was surprised, thought we were going to have to find a bigger tractor the first time....
ALLIS EXPRESS!
This year:
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 4:05pm
At full rpm it is at 11.4 gpm. Run it at 2/3 throttle or less would meet the spec.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 11:59pm
I will be using the 6080 to run a hydro-push manure spreader tomorrow. I see in the spreader manual that the hydraulic flow rate should be no more than 6.8 gpm or it may cause a pressure drop. According to tractor data, the tractor is rated at 11.4 gpm. I can't see in the manual where this can be adjusted....will this be a problem?
spreader we will be using:
http://www.pikrite.com/wp-content/uploads/2013/02/HR250.pdf
ALLIS EXPRESS!
This year:
