6080 foot throttle
cowkicker View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Topic: 6080 foot throttle
    Posted: 19 May 2018 at 4:13pm
Could someone post some close up pics of 6080 foot throttle parts and pieces mounted on a tractor?  Thanks
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 10:31pm
I was going to do the same thing to mine.  Screen shot of the parts diagram.
These are the parts I picked up at the junkyard and I had to buy the bracket which bolts on the block.  I did not get the spring which is on the long end of the rod, parts tractor was missing engine.
The bad part is the foot pedal part looks like it was welded together after it was installed through the sheet metal.  The junkyard was good enough to cut around it with the torch.  I'm not sure how it will go together, one of those projects I will do when I get more time.  Here are a couple of pictures another forum member sent me of one installed on a unit.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 8:15pm
Thanks for the pics. Is bracket #4  a replacement for bracket #12 when adding foot throttle? I  don't have any pieces, just trying to figure a way to make something myself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 12:30am
Yes, one bracket is for dash and foot throttle option and the other is just for dash throttle.  Would be best if you could see one in a salvage yard but they are getting hard to find.
