6080 crank pulley ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 6080 crank pulley ????
    Posted: 12 Oct 2019 at 11:23pm
Hi everybody. Is there anything needed to know to remove the front crank pulley off 6080. With the thrust bearing thing on there you don't get a good visual of what holds it on there, I know as much as to remove that bearing holder and bearing but what's under that. Thank you
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2019 at 6:47am
Loosen bolt in front, with good puller, pull from the three bolt holes in front of pulley.        MACK
