6080 Air Conditioning controls
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: 6080 Air Conditioning controls
    Posted: 12 Jul 2015 at 9:31pm
I am gutting the cab of my 6080 so that I can prepare for installing a new cab interior.  I am having a problem removing the HVAC control panel.  How do I remove the cable from the sliding temperature control?  Also, there is a hard wire (or small metal line) coming from the air conditioning switch, is there a way to disconnect it?
These are the only 2 things holding that panel on.  I would like to have it out of the way when I go to put in the new headliner.
Also, do I have to loosen up the hydraulic controls to fit the new interior in that area?
Thanks for any suggestions!
Edited by DSeries4 - 12 Jul 2015 at 9:39pm
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2015 at 10:57pm
Cable attaches to heater valve over head inside top of cab may be easier to go ahead and pull top cover the wire that goes in slider has a heck of a bend in it , the metal line goes to expansion valve I think thats what its called and is fixed with a clamp if my memory serves me right and I do believe you take cover off the remote valves controls to form cab kit. I got into this 3-4 years ago when I redone the cab and A/C on my 6060.
This page was generated in 0.057 seconds.
