6080 4wd front diff shaft sheared
AC6080MAINE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC6080MAINE Quote  Post ReplyReply Direct Link To This Post Topic: 6080 4wd front diff shaft sheared
    Posted: 13 Jun 2017 at 9:18am
I bought the tractor like this. Why would it have happened? Could someone help point me in the right direction on getting this fixed?  I tried to purchase a shaft from the dealer and they told me it had been discontinued for several years and was not available.  Should i call around to yards and see if i can find one used?  Part #17
Edited by AC6080MAINE - 14 Jun 2017 at 8:53am
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2017 at 8:51pm
see if you can resize your picture  ( too big)
check your tire sizes front to rear, if the sizes are not in sink with the gear ratio then that would cause a binding in the drive train and broke the weakest link.
IMO.  dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
warbys54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote warbys54 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2017 at 9:34pm
Just fixed mine found a shaft at a junk yard they run about $1500 mine had been welded at the coupler and looked just like yours
Aus D19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aus D19 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 5:24am
The front axel pivot bushes are worn causing a side load on the pinion shaft.The parts are available,the transmission and fwa unit is the same as a Fiat 880 DT four cylinder model,i needed a complete drive shaft for a 6080 and got one non genuine through a Fiat parts supplier reasonably priced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC6080MAINE Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 8:50am
Tire sizes are correct but the front tires are like new and the rears are pretty worn.  I'll see if i can resize it.
Holy Smokes... $1500!  I think i might have to stick with 2wd for a while.  I think when i was looking several months ago i found a whole front diff for less than that though.
Aus, i've tried to look up Fiat parts but i cant find any FWA pinion shaft available for an 880DT.  Might be because i'm in the states?
Thanks guys
chuck (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 6:56pm
If its the same as the fiat 880 it looks like import tractor parts has a new ring and pinion for $1150.00
