6080 3 pt question
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: 6080 3 pt question
    Posted: 10 Aug 2012 at 8:47pm
One of our 6080s developed a new "quirk" recently.  It now has the tendency to have the lift arms drift down while it is shutoff.  What could the cause be?  They return to there proper position shortly after start-up.
soybreedingboy77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soybreedingboy77 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 9:38pm
If there is no external leak then there is an internal oil leak. The 6080's 3pt system is a one way cylinder that sends oil until it is at the correct height. It would be the same as if the arms were all of the way down and prior to starting the engine you moved the leaver into the raised position, as soon as the engine turned over the first place oil would go is to raise the arms to the position indicated by the leaver.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 10:38am
My 6060's done that for as long as I've had it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 8:48pm
Mine just started that this week
