6070 thrust bearing beefed up??
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Topic: 6070 thrust bearing beefed up??
    Posted: 19 Jan 2019 at 9:40pm
When you guys refer to the thrust bearing being beefed up in the later models are you talking about the number four main crank shaft bearing and thrust washer combo? I am doing and in frame overhaul using a Reliance kit recommended by my AGCO dealer. The number four main and thrust bearing that is in the kit does not look to be the same as what I removed it has a lot less surface area for the side to side thrust part of it. When I ordered the kit I told them I had the later engine and gave them the serial number which they said didn't mean anything to them. I can't find anything on the AGCO parts book that helps me out. If any body can explain this to me I would be most grateful.
rieg
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 10:02pm
Don't know the particulars but yes.What has been said here before is that the latest ones had a larger surface area thrust brg.Sounds like that's what yours is.Sounds like what you got is the earlier style.
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 10:05am
Thanks Steve does anyone know the engine serial number break or tractor serial number or do all 6070s have the heaver thrust bearing?
rieg
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 12:24pm
Pretty sure the 6070,s should have it as they were last production and I remember seeing a bulliten as of mid 83 they redone the blocks
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 6:23pm
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 10:07pm
Thanks so much guys looks like Reliance sent the wrong thrust bearing my tractor should have the updated one. I hope they will rectify this problem. Once again you guys are amazing Thanks again.
rieg
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 7:05am
Take your bearings ( old ones also ) along back to where you bought them .Have them check sizes. Then have them look them back up under reliance . Reliance is not the problem.
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 8:57am
I thought awhile back I read on here that when you order from agco you get the updated version and whenever you order aftermarket company's they come in the old style. I know this sounds crazy but when I ordered for my 6080 and mine is the old style, I got agco bearings and they came in the updated style. Then I came on here and was told that and ordered from aftermarket and sure enough it was the old style. Try it from agco
Like I said sounds crazy,
Edited by Mikez - 21 Jan 2019 at 8:58am
This page was generated in 0.381 seconds.
