6060 won’t move |
Rafterg
Topic: 6060 won’t movePosted: 12 Dec 2021 at 8:13am |
I have a 6060 that yesterday all of a sudden would not move. Seems to go into gear both high and low and all gears. Any thing I should take a quick look at that might be a simple fix that I am overlooking.
Mikez
Posted: 12 Dec 2021 at 8:29am |
welcome to the forum.
How’s the clutch pedal feel.
Rafterg
Posted: 12 Dec 2021 at 9:00am |
Like it has since I have owned it. There is not much travel down below though. It seems like it does not have much resistance
Edited by Rafterg - 12 Dec 2021 at 9:05am |
DougG
Posted: 12 Dec 2021 at 2:22pm |
So it goes into all gears with no grinding at all??? Are you sure the main transmission is really going into gear?
Posted: 12 Dec 2021 at 3:08pm |
I'm going to say the range lever (high-low) is in neutral.
Rafterg
Posted: 12 Dec 2021 at 6:48pm |
So the high lo seems to be going into gear, is there a way to tell if it is stuck in neutral
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2887 |
Posted: 12 Dec 2021 at 7:22pm |
Pin out of rear end?
Posted: 12 Dec 2021 at 7:46pm |
If the differential pin has fallen out, a quick test would be set the parking brake really tight. Try to move the tractor then. If it kills the engine, the differential area is the problem and quit trying to make it move!! to save on the damage.
victoryallis
Thanks(1)
Posted: 13 Dec 2021 at 5:00am |
Does it have pto ? From my limited experience the diff pin typically takes the pto with it when it backs out.
Rafterg
Posted: 13 Dec 2021 at 7:47am |
The pto turns when turned on.
Posted: 13 Dec 2021 at 8:01am |
TRY THE PARKING BRAKE !!! and see if it pulls on the engine !!
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5469 |
Posted: 13 Dec 2021 at 11:34am |
That’s a issue I haven’t heard before, pin out of the pinion. Hope it’s not that. I would have guessed hi/lo in neutral also.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 13 Dec 2021 at 11:42am |
Pin out of differential spider gears....can cause GREAT harm.
victoryallis
Posted: 13 Dec 2021 at 12:00pm |
That’s an understatement |
victoryallis
Posted: 13 Dec 2021 at 12:01pm |
Shift lever broke off below the transmission cover? BTDT.
Rafterg
Posted: 13 Dec 2021 at 5:43pm |
Tried setting the e-break and it did not kill the tractor. While it was started, I could shift the tractor with not having the clutch pushed. Pto engages
Posted: 13 Dec 2021 at 5:45pm |
Problem is then clutch or transmission input issues.
DougG
Posted: 13 Dec 2021 at 6:28pm |
There are 2 dowel pins on the main shifter that do back out at the shifter base - check those
Rafterg
Posted: 13 Dec 2021 at 7:08pm |
On the high low or gear. How do I access to see.
DougG
Posted: 14 Dec 2021 at 6:11am |
In the main 1-4 transmission lever, take the rubber boot off to see
Mikez
Posted: 14 Dec 2021 at 8:12am |
not to change the subject. What other allis do you have.
Posted: 14 Dec 2021 at 9:13am |
With the engine running and the range lever in gear (low or high I don't care) foot OFF the clutch, you should feel gears grinding when trying to shift into 1 or 2 (non-synchro) and you should NOT be able to get the lever into 3rd or 4th. If you can, the input shaft must not be turning. Are you sure your clutch pedal is released?? The pedal should come up probably 6 plus inches from bottom with your foot off the pedal.
Mikez
Posted: 14 Dec 2021 at 9:16am |
dr is that cable for clutch pedal like 6080.
Rafterg
Posted: 14 Dec 2021 at 10:58am |
Last night I started the tractor to see if I could kill with the e-brake and it would not. I then thought I would see if I could change gears without pushing in on the clutch. I could move through all gears and hi/low with out anything happening or grinding. It is like if the clutch pedal is pushed down and doesn't release. When I go under the cab though, the clutch cable moves the arm that goes into the clutch.
Posted: 14 Dec 2021 at 11:31am |
And the clutch pedal foot pad moves a total of at least 6 inches or more top to bottom ?? And the resistance/effort required to depress down on the pedal is the same as it always has been ?????????
Rafterg
Posted: 14 Dec 2021 at 11:52am |
Yes, that is correct. The only thing that seems odd is the amount of travel down below. Doesnt seem like a lot by I also now it does not take much travel to engage or disengage the clutch.
Mikez
Posted: 14 Dec 2021 at 5:44pm |
is it moving the clutch lever on side of bell housing
Rafterg
Posted: 14 Dec 2021 at 8:34pm |
Yes it is moving the lever on the side of housing
