6060 pto problems |
SobersRunSawmill ![]() Bronze Level ![]() Joined: 27 Jun 2023 Location: 18091 Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Jun 2023 at 2:40pm |
Hello, first post here. Just bought a 6060 with a pto issue. The previous owner was using it to brush hog and hit a tough spot and said pto just stopped working. I've checked all the linkages and it appears that the clutch is working properly. When I engage the pto with tractor off, there is absolutely no resistance. Has anyone had this problem before? I plan on removing pto to see if a shaft snapped
May have sheared a pin in linkage inside on left side. Pull cover off park brake on left side. MACK
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5227 |
Curious to how you tested the clutch? With the tractor at idle, I’m guessing that you pulled back the temporary pto disconnect lever on the right? Has the yellow handle. And then pulled up on the pto lever located at the floor to the left of the seat? Did it grind as you pulled up on it? And then release the temporary pto disconnect lever slowly? That’s the proper way of engaging the pto if you followed those steps. Just want to verify that’s how you are engaging it. Previous owner hit a tough spot? Like a stump or rock? Or just thick grass? Asking since you are new to the tractor.
Edited by AC720Man - 27 Jun 2023 at 8:34pm |
It didn't grind at all. I guess what I meant to say is the clutch disconnect feels like it's functioning properly. Has tension on it when pulling back, and goes front nice. Linkage underneath appears to be moving correctly. As far as the "tough" spot while mowing, that's as much elaboration as I received. I bought the tractor through the owners grandson. The owner is in a nursing home so I didn't get to talk to him really.
That's going to be one of my first moves. I have a feeling it's not going ro be that simple since it stopped working under a heavy load, but time will tell
If it didn’t grind when pulling up on it then like Mack said something is broken. Every 6060-6080 owner that I have talked to, they all grind as the pto lever is engaged. It’s just a nature of the tractor. I normally shut our tractor off to engage just because I do not like to hear it grind. If I remember correctly there is a collar that connects the pto shaft. When we split our 6060 to replace the clutches that is a concern, it will drop out of place if you don’t follow the procedure in the manual. And it’s a bear to get back in place from what I was told. Access to it is at the parking brake access Mack was describing. That was 5 years ago, need to look on AGCO parts books again to see the parts breakdown.
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
I don’t get the fascination with pulling the side cover. If you pull the seat and that rectangular piece of tin under the seat there is a square inspection plate. Pull that plate and you have a birdseye view of the coupler. With that plate off you can manipulate the seasonal disconnect and watch it move. I bought a 6080 that someone had the coupler backwards. I had a great view of what went on. Edited by victoryallis - 29 Jun 2023 at 5:15am |
Thanks for that piece of information! I will make a not of that in my manual.
Acdiesel ![]() Orange Level ![]() ![]() Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2576 |
pulling the parking brake cover requires patients to reinstall in order to line up the brake pads and the discs.
![]() I know its been stated but I'm gonna say it again ![]() with the long handle, PTO hand clutch engaged (on the right side) and the tractor idling, if you pull up on the PTO handle on the left side of the seat you should get a grinding noise. (we always shut off our tractor to do this, but its okay for testing purposes) It could just be the roll pin that holds the lever to the collar has broken or fallen out. I've seen it before. Dan |
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4076 |
In all the years I've been around Dad's, (now mine) 6080, I've never engaged the p.t.o. Since it is the loader tractor for the farm and plenty of others to do the p.t.o. work, just haven't ever used it for that purpose.
I’d say 1/4 of the hours on our 6060 is pto time.
I'm going ro be ordering a manual for it before I tear into it just to be safe. I'm going to start at the back and work my way front until I find the issue
Gutter ![]() Bronze Level ![]() Joined: 05 Jul 2025 Location: Illinois Points: 2 |
Did you figure out your issue?
I have a 6060 having a similar issue, I get grinding when running and engage the left side disconnect(not my normal method, normally engine off), the right side yellow engage handle moves but the shaft going into the transmission does not move. The pto will work but it’s full time on. I read above that it may be froze in the tube, I am a little nervous about hammering on it, and breaking something. Is there a best practice for freeing it up? This issue has been in place for about 5 years, the tractor only sees about 60 hours a year so I have lived with it. 2 times recently I have noticed that while moving then depressing the clutch it does not stop moving, let up clutch and depress clutch again and it actually clutches - not sure if these could be related. |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7499 |
You are not supposed to touch the lever on the left with the engine running! That is the seasonal disconnect. Using it with the engine running can cause some serious damage. It is to be moved ONLY when the engine is off. The lever on the right is the main control when using the PTO.
I agree. Several in the above in this thread suggested moving the seasonal disconnect to test and isolate the issue. That’s not my issue. My issue is how to free up the main control without damaging anything.
