6060 power steering problem |
Post Reply |
chefiam1
Bronze Level Joined: 20 Sep 2019 Location: centerville,pa Points: 17 |
Posted: 10 Jun 2021 at 11:38pm |
6060 power steering.
replaced the hand pump. but still does the same thing when i try to turn i have to keep on turning the steering wheel to make a easy turn. stumped! all help would be appreciated. thanks, chef
Orange Level Access Joined: 12 Sep 2009 Points: 19507 |
In 45 plus years, I have never changed out a steering orbitrol on any AC tractor. Rebuild your steering cylinder.
Edited by DrAllis - 11 Jun 2021 at 6:21am |
chefiam1
thanks i will look into cylinder rebuild
chef
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22810 |
Yep, cylinder is leaking past the piston. On my little utility tractor, I noticed if you drove very far in a straight line, you had to keep turning the steering wheel to the left to keep going straight. Put a kit in the steering cylinder and all is well.
That may be true on some tractors and not true on others. In the case of a 170-175-180-185-190-200-7000 etc, etc one end of the steering cylinder has more volume than the other, so when constantly turning the steering wheel back and forth (field use) the steering wheel usually gains to the clockwise. Nothing wrong. Just the way it is. Some tractors have a balanced system where the steer wheel might stay the same most of the time. Again, nothing to worry about as long as it drives well and turns well.
CTuckerNWIL
I used to work for a guy that had a 170 diesel. if you drove straight down a road for a mile, you had to turn the wheel to the left nearly a full turn. I believe that was the same problem, oil leaking by the piston. |
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8146 |
had weird stuff going on with 6080 like that. Had steering cylinder seals done and fixed it
Normal. Unequal displacement between each end of the cylinder.
Post Reply | |
