6060 3 pt hitch won't raise |
DougG
Topic: 6060 3 pt hitch won't raisePosted: 04 Oct 2016 at 5:50pm |
Got a 6060 that the 3pt hitch will not raise, cables all good, just no response at all from the lever,, any help appreciated
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7574 |
Posted: 04 Oct 2016 at 8:43pm |
Try moving the traction booster lever.
MACK
Posted: 04 Oct 2016 at 9:25pm |
There is a plug on valve body under your seat. Remove plug, under plug is a valve that must seat to lift. Remove this valve and check for any thing under valve keeping it from seating. MACK
DougG
Posted: 05 Oct 2016 at 4:03am |
Traction booster lever is froze hasn't moved in years, thanks Mack I'll try that!
Posted: 05 Oct 2016 at 6:24am |
If the Traction Booster lever is frozen and hasn't moved in years, I sure hope it's all the way to the rear. Both levers have to be rearward for the hitch to raise.
