6000 coolant conditioner filter |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8698 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Jun 2015 at 10:55am |
Does anybody have pictures of factory mounted and pluming of the water filter and lines. Or if you have one on your 6000 how does it look. Going to put one on and figurd make it look good. Thanks
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7491 |
My 6080 has one. It's on the left side, tucked up under the side shield, close to the cab.
No pictures, but it is a nice job. None of it is visible with the shield on. |
Also would it mater if I use a filter set up off a cat or Cummings engine. I can grabe one out of neighbors scrap bin.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21779 |
You can also just use the correct type of TREATED antifreeze and the problem is solved.
Hurst ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Midway, Ky Points: 1218 |
Make sure if you use a filter, you use the correct one for the type of antifreeze. If you are using ELC (the red stuff), you don't want the filter with the SCA additives, you just want a plain filter. If you are using the traditional antifreeze (green or yellow usually) then you'll probably want an SCA filter unless you are manually adding the coolant additive and testing it on a regular interval with the test strips.
Hurst
1979 Allis Chalmers 7000
5800 Hours |
Ok thanks. Yea the ones laying there from the trucks are older and used green like tractor then ill get new filter to go with it.
