6 cyl stationary motor
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Topic: 6 cyl stationary motor
    Posted: 30 Jan 2012 at 7:43pm
Going to go look at a stationary motor soon. The guy said it came out of a hospital that used it for a back up power. He said it looks like the ones on gleaner combines. My guess is a buda. He said it was run on lp. What should I look for on it. turns over the paint hasn't even been burnt off the manifold yet.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 7:46pm
I suppose it could be a Buda or a Chevy engine. Either way is the coolant rusty, oil clean, hoses not leaking. Stuff like that.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 8:00pm
Take pictures.
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2012 at 9:56am
it should have an hour meter on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 9:50pm
 went to look at the 6 motor today. forgot the camera. HAVE NO CLue what it is. from the back the dist. and plugs are on the left. and the right has the manifold. No I.D. tag to be found the generator is still atached. head seamed wide and had treaded head studs th the right of the valve cove above the manifold. top water hook up was on the left side of the head. If it is a Allis motor I have no clue. Any one on here have a top view picture of a gleaner 262 or a 190 gas motor? It  had like these inspection plates on the dist side of the block. Still have no idea what it is.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 10:09pm
Sounds like a 262.  MACK
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 10:30pm
Inspection plates sound like a Chevy? Water outlet would be on right hand side of head behind the intake/exhaust manifold on a Buda 230/262.
Edited by Travis(NE) - 04 Feb 2012 at 10:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 11:39pm
Chevy engines had inspection plates and distributor on rt from flywheel end and manifold on the left. AC engines had dist on left and manifold on rt- rear view and no inspection plates.It's neither.  Ford or Chrysler?
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 12:43pm
  WE HAVE AN 8 CYL [STRAIGHT 8]  1290 CU.IN.  KEPT IT FROM SCARP  279 HRS.
  TOOK IT TOA LOCALSHOW THIS FALL  RAN IT ABOUT 6 TIMES  ON LP  8600#
   IT IS HEAVY  8 FT. FORM  GROUND TO TOP OF RADIATOR
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 2:27pm
can you say Studebaker? bunch of the inline 6's were put on generator sets that ended up @ small hospitals, waste water treatment plants, police/fire backup units. have fun.......tp studer, wooster, ohio.
