6 Bolt Hub D17 Series 2 |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Topic: 6 Bolt Hub D17 Series 2Posted: 28 Mar 2026 at 6:38am |
What does it take to put 6 bolt hubs on the front of a D17 Series 2? From the 6 times I've read the parts book all the bearings and cones are the same. The only difference is the hub cap and seal. I always thought one bearing was different and guys on Facebook are telling me the same, but the parts book doesn't back that up. AaronSEIA
Posted: 28 Mar 2026 at 7:44am |
It's been too many years ago, but I believe it was always the (larger) inner bearing and cup that were different. The outer bearing/cup remained the same. The six bolt hub design was for more weight carrying capacity. Use the series 4 parts book and then a 170 parts book ( 6-bolt only) and you'll kind of see that. On that larger inside bearing they listed two different bearing cones ( 70047751 and 70209899), but only one cup. I don't know why. Maybe one number was discontinued and it subs up to the other number ?? I also see the original 6 bolt hub was 70236706 and then the later was 70261418. I think old was a screw on cap and the later was a drive on cap.
AaronSEIA
Posted: 28 Mar 2026 at 10:02am |
Interesting. The Series 4 parts book lists the following numbers: hub 70261418 outer cup 70209983 outer cone 70209926 inner cup 70209987 inner cone 70222214 Oddly that hub number calls for a drive on cap but the aftermarket world seems to have threaded it for the screw on one. All those part numbers are the same for the 5 bolt hub. AaronSEIA |
Posted: 28 Mar 2026 at 3:36pm |
I'm thinking now the spindle diameter is different as the series 4 has two p/n's for the WF spindles at a very late serial number. 70236706/70261418 are the 6 bolt hubs. 70237438 is the 5 bolt hub. 70209899 should be the inner cone and 70235089 should be the cup for 6-bolt hubs. Part numbers change over the decades and sometimes they do get entered into the on-line parts system. Sometimes not.
Edited by DrAllis - 28 Mar 2026 at 3:45pm |
VaAllis1990
Joined: 26 Jan 2022 Location: Champlain Va Points: 33 |
Posted: Yesterday at 8:35am |
Per my original parts book, outer bearing and cone are same for 5 and 6 bolt hubs.
Inner cup is specific to the hub, inner bearing is specific to hub AND front end Inner bearing: 5 bolt- 222214 6 bolt roll shift front- 209899 6 bolt dual front wheel- 4254794 Inner cup: 5 bolt- 209987 6 bolt- 235089 Outer bearing: 209926 Outer cup: 209983 Also, on a narrow front, the bearing spacer has a different OD depending on felt or rubber wheel seal |
Joined: 11 Sep 2009 Location: illinois Points: 90774 |
Posted: Yesterday at 8:53am |
I dont know the specific bearing listed.. but if you had a spindle and a hub, and you wanted to Increase Capacity... you can buy a bearing with the SAME ID that fits the spindle and a LARGER OD for a NEW HUB, and the larger bearing would have a greater load carrying capacity most of the time... Use the ORIGINAL SPINDLE ...Normally itis not the SPINDLE that is the limiting factor.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4273 |
Posted: 11 hours 50 minutes ago at 6:41am |
When I put 6-bolt hubs, (from a hundred series tractor) on my 45, had to get series 4 D-17 spindles to make it work. I have a feeling you are headed down a similar road. You will need the steering arms to go with them most likely.
SteveMaskey(MO)
Joined: 11 Sep 2009 Location: Wellsville, MO Points: 634 |
Posted: 9 hours 58 minutes ago at 8:33am |
Do like Steve above says. Find a good auto parts or bearing store and buy the cups and cones separately. We put 6 hole hubs on my dad's series 1 D17 back in the 80's because he was breaking the center out of the 5 hole rims moving round bales
