5020 electric clutch
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: 5020 electric clutch
    Posted: 16 Aug 2014 at 5:59am
Working on a 5020 four wheel drive with a model 64 snowblower on the front. The electric clutch is bad. Where would I look to find another clutch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2014 at 8:09pm
Good luck, got one from AGCO for about $800, lasted about an hour.  Bought a used Land Pride rear mount for $650 instead.
Simplicity dealers may be able to get one too.
Edited by TedBuiskerN.IL. - 17 Aug 2014 at 8:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2014 at 8:38pm
That is what I recommended.I wonder if an electric clutch from a larger lawn mower could be retrofitted?
Good to hear from you Ted.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2014 at 8:06am
I had trouble with the wire they ran for the clutch on my 5020.  It broke inside the insulation.  I also remember having one of the fuses blow causing a problem with it.  Did you hook a battery right to the wire at the clutch?
I was looking for one for a friend for his Case garden tractor and found many when I Googled it.  You just need to know the specs.
Edited by john(MI) - 18 Aug 2014 at 8:08am
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2014 at 1:41pm
Hi Lonn
Can you post a picture of the clutch?
Possibly of it on the tractor.
or can you tell me a better description of the problem with the clutch,
like is it the coil field end, the middle rotor or the armature/ pulley end or a bearing on the coil/field end or the armature/pulley bearing end?
Don't know for sure, but maybe we can help you!
DeWayne Spears
Edited by DSpears N IL - 18 Aug 2014 at 1:47pm
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2014 at 9:06pm
Have a somewhat complete new front electric clutch for a 5015.  No idea how compatible it would be for your application.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2014 at 6:21pm
My neighbor has the machine. He brought the clutch over for me to see. Says it was red hot. Not much of the coil or wires are left.
There are many electric clutches available but would have to get the specs of the original then retro fit a new one.
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2014 at 7:36pm
The Allis-Chalmers 5020 is the same as the Simplicity 9523
and similar to the Hinomoto E23 and Massey-Ferguson 210.
http://www.jackssmallengines.com/Products/SIMPLICITY/Electric-PTO-Clutches
i have found that some ac pump off of a car/truck
had the same clutch that you can change parts
or machine to fit
 For proper ordering, reference Warner or
Ogura part number stamped on clutch
HTH
        B:-)         Dnoym
gleasman1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gleasman1 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 12:42pm
I have an AC 5015 that needs a new PTO clutch.  Do you know what might work to replace this?  I am new to this sort of forum...but really need this to work!  I love my tractor...and don't want another mower.
This page was generated in 0.050 seconds.
