5015 hyd. pproblem
bacon6 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bacon6 Quote  Post ReplyReply Direct Link To This Post Topic: 5015 hyd. pproblem
    Posted: 19 Feb 2011 at 4:57pm
I just purchased an '83 allis chalmers 5015 tractor and am having problems with the hydrolics, the fluid looked contaminated w/water so I changed it & filter, espicialy when warmed up seems to strugle to lift, sometimes won't lift at all, I've heard of a possible internal filter that needs to be cleaned but no one knowes where it is, any help?? everything else working fine, trans. pto all good
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 5:26pm
Have you checked the fluid level.  Also If water got into the system, the fluid is contaminated and will clog the filter again.  There is only the single filter per the AGCO parts book.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bacon6 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 7:04pm
that makes since when I changed the fluid I installed a small "oil filter" that matched up the to help clean up the system before installing the proper filter, everything worked fine at first but after acouple hours of run time stoped working again Thanks
GARY(OH/IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY(OH/IN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 12:33am
I'll jump on the back here with another 5015 hydralic question. The loader fades with or without weight in the bucket. The 3 point arms hold good though. Any suggestions?
mtanut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mtanut Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 6:58am
I am going to guess you have two different issues. Your 3 point will have an internal valve for the 3 point, and your loader has a separate valve assembly. because it would tie in to the external ports on the tractor. I think you need to rebuild your loader valve.
I have a 185 Allis, 6060 Allis, Model K gleaner, SMTA ferg 35, ferg 20 (paps first tractor, Allis B (wife's)John Deere 240 skid loader and a bunch of the usual farm stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bacon6 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 6:53pm
another question,is there any fluid I can use to flush the system other than regular 303 hyd. fluid, seams to be getting better as I change filters but feel a good flushing is in order Thanks
oldwelder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldwelder Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 12:27pm
I had the same problem with the bucket drifting.
I replaced the O rings in the cylinders..
You can pick them up at NAPA or order them on line.
There is a nylon O ring in there also.
I did not replace it
Bucket  is holding up fine for the last 1 1/2 years .I use my AC 5015 for just about everything ,,5 ' woods deck 3 point
4 ' tiller
Hauling wood in the wither ,plowing the snow ,and digging up dirt
I have a 1983 with about 1400 hours on it.
This page was generated in 0.095 seconds.
