5015 Engine Rebuild
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Topic: 5015 Engine Rebuild
    Posted: 02 Jan 2019 at 10:11am
FYI
Am doing an overhaul on my 5015 and found a supplier for engine parts.  I wasn`t aware that there were parts available for this machine.  The company name is Southern Global Tractor in Wiggins Ms.  They deal in parts for most japanese models.  Just hang on to your wallet.   Std, rings are $90.00 a hole, Std rod bearings are $75.00 per rod.  Full set of gaskets is $250.00.   Head gasket purchased separately is $95.00.  Imagine if this were a 6 cylinder instead of a 3 cylinder!
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 3:27pm
Good to know about this source.  My old 5015 is still going, but will need work sooner or later.  I found a company on ebay, J&M gaskets that sells head gasket, and valve cover gaskets, listed for the MF 1010 which is the same Hinomoto tractor,  but shipping from England was as much as the parts. I did get a valve cover gasket from them, which is keeping the old girl from slopping large amounts of oil on my shop floor.
Thanks again for the post.
