500 loader tip cylinder |
Don Jr NY ![]() Silver Level ![]() Joined: 11 Sep 2009 Location: Waterloo NY Points: 347 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Oct 2020 at 4:03am |
Hello all. Would anyone have an old 500 series loader lying around they are parting out? I am looking for a tip cylinder for one. The cylinder from a 400 loader is a different length so it has to be from a 500 to match my other one. Any and all leads appreciated. Don Jr.
Anyone out there have anything? Thanks.
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10697 |
Don, don't give up. They can be had time to time. If you can wait might get one. I was about a year before I found one here. If you need one soon, might as well have someone make them or covert to standard from a hyd supplier. HTH Tracy
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 33187 |
Gonna hate it if have to find a New One. About the only way to get one now is to have a GOOD Hydraulic shop build one. They generally have all the tooling to do this or access to suppliers for a basic cylinder that can be reduced in length to produce a replacement.
Uncertain how long the supplier I am using will remain in business as the owner has no one beating his door down to take over and he is closing in on retire. He services close to seven states.
steve fischer ![]() Orange Level ![]() Joined: 11 Jul 2011 Location: sleepy eye mn Points: 982 |
I can get aftermarket to fit not cheap , thanks
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4680 |
Check Surplus Center in NE they have 100 and 100 of cylinders match up the length of throw. The ends can be changed with some cutting and welding.
