5 Rail Front Tires D21 #1001
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Topic: 5 Rail Front Tires D21 #1001
    Posted: 20 Jan 2015 at 7:50am
Morning. In the process of getting some front tires for #1001 D 21. Going to do little things here and there for the slow over the next 3 years restore of the thing(Other projects before it). Looking in Norm Swinfords book, the early photos of the D 21 had a 5 rail front tire of 11.00x16. I have bought from Speciality Tire in Firth Nebraska in past and see that they have a 5 rail titan tire. I want this think to look as stock as it did when rolled off line and be correct with the "Allis Police" Or I could put a 4 rail front on and look close. In the rear, I will get a 45 degree tire in a 24.5x32 rear. Will be most likely a different name brand than front. Want you advice on this and point in right direction.
Thanks in advanced Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2015 at 8:02am
Nebraska Tire is the name. Just checked again. Thanks
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2015 at 8:35am
most of the 5 rib front tires have a very shallow tread depth. 4 ribs are usually very deep.
