5 bottom 70series sterable plow ???
b170dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote b170dr Quote  Post ReplyReply Direct Link To This Post Topic: 5 bottom 70series sterable plow ???
    Posted: 20 Apr 2012 at 1:26am
I have a 5bottom 70 series stereble  wheel plow that had the bottoms removed. It had slaught bottoms. I remember a 190 xt gas pulled it easy.  I just bought an xt gas and want  to put bottoms back just  for a plowday rig. Does a slaught pull easier than a solled molboard, What number bottoms would i be looking for. It use to lay sod like a  ribbon. Need some response to  this Thank you
'64 B-10, '58 D-14, '60 D-15D, '58 D-17D, D-19, 170, 2-185D, 190, 68 D-21 11, 72-220, 7000,7030, F-2 G,w/5 Heads,L-2 G, 330 No-Till
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 6:08am
If you got a lot of clay then slat bottom helps. Used to be a lot of slat bottom plows around here way back. Scrappers got most. Brother has a 3 bottom somewhere on the farm. It ain't for sale though cause I tried to buy it once.
Wink
I am a Russian Bot
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 7:51am
Most any bottom of the right width (and the 70 frames can be bolted together for two widths) will fit. I think bottoms and for sure shares were chosen for the soil and the available horsepower. Some had longer moldboards for smoother rolling, some where shorter and twisted faster. Some bottoms show as many as a dozen shares for a given width, made of different materials and shaped differently. Some like chilled iron wear best, until they hit a rock. Some have a longer nose to dig in better.
Today the modern 387 bottoms have more parts available aftermarket than any others.
Slatted bottoms were used mostly for very sticky soil that stays together with little support. They would be poor in sandy soil letting much of the sand slip through between the slats.
One place to study the possible bottoms is in the bottoms manual that you can download from http://www.grandpastractor.com/phpBB3/index.php That manual dates from 1968. There are newer editions but I've only seen one on the counter of a current AGCO dealer.
Gerald J.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 8:25am
Are the frogs still on it, or was it stripped completely? I'd say the solid 387 bottoms are going to be the easiest to find parts for. Shoup and other have moldboards, shares, shins and landsides avalible. An XT should handle 5 - 16's just about anywhere.
AGCO My Allis Gleaner Company
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 10:23am
Dave in il almost anywhere my xt with new firestones filled and wheel weights and cab had a hard time with 4-16 allis 2000 series im from sw pa lots of limestone and limestone/clay here it will make the 7045 with the same plow work hard.
  Shawn
190XT,D17and 7045
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 11:38am
  Shawn
I can pull my 3 bottom with a D-17, worn points and bottoms not scoured 8" deep in my sandy loam with no problems.  Move over to where I have Texas red clay and in some places stops the tractor dead in its tracks.
1944 Allis C
1960 Allis D-17 LP
