460 loader |
Trinity45 ![]() Orange Level Access ![]() ![]() Joined: 17 Mar 2014 Location: Kentucky Points: 1821 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Aug 2017 at 12:14pm |
How hard would if be to mount a 460 loader to a 175 or 185, looks like they were made for the 6000 series tractors???
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7433 |
Yes, the 460 loader was made for the 6000 series tractors. Will it mount on a 175/185? Anything can be made to fit with enough cutting, welding, modifying, and money. I highly doubt that it will bolt on. Never tried, but those are my 2 cents.
Reindeer ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Calgary, AB Points: 650 |
My 170 has a 460 loader on it that someone rigged up before I bought it. Looks like they spent a lot of time and a substantial amount of money to get it done, and still not connected to rear axles. Works well after all that.
SteveMaskey(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wellsville, MO Points: 610 |
Brother put a 460 loader on a D19, he used 500 loader brackets. Looks factory
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21361 |
A loader that size if used heavy will eventually break the tractor in two if it doesn't have rear axle connection. I've fixed two 185's and a 200 that had Koyker loaders on them. Broke in half right thru the belt pulley hole.
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
The bucket is quite far beyond the front of the tractor. This increases the 'moment' at the center of the tractor. Otherwise it looks like a nice install.
And when those tractors broke in half, it was a "momentous occasion".......
I Too have seen a 200 broke in half that had a quick attach loader with no rear axle connection
