460 AC loader tilt cylinder replacements
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 460 AC loader tilt cylinder replacements
    Posted: 04 Sep 2012 at 2:31pm
Im working on a 460 AC LOADER and one tilt cylinder is leaking and bent pretty good , the other looks ok and not leaking , anyone kno of a good place for replacement cylinder ? I think this ones factory , its 36 inches from pin to pin anyway , 1.5 in bore , needs to be 2.5 inches wide where the pins go
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 5:05pm
Look on surplus center. com. I have found what I need there before. Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 5:46pm
10-4 that , ill check it out
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 8:31pm
a good hydraulic shop should be able to fix that cylinder that you have there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 9:17pm
I was thinkin about that, the rods could be straightened but im not sure about the tube? ???
JIMncMO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JIMncMO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2012 at 7:48pm
I Just had the same problem.  I never could find the exact same cylinders anywhere.  I found a hydraulic shop that ordered new pistons and rebuilt my cylinders for less than half of what my local dealership wanted for A-C replacements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2012 at 9:00pm
Yeah i found close but not exact -- i took it to Mexico- Alzdec hyd shop there gonna fix it up and get a packing kit for the lift cylinders, when i got the lift cylinders apart the packings just crumbled, they aren't bent just leaking
This page was generated in 0.754 seconds.
