444 Baler knotted brake |
Driverdan ![]() Bronze Level ![]() ![]() Joined: 21 Feb 2015 Location: Owego,NY Points: 175 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Jul 2015 at 9:13am |
Can anyone help me please?? Was bailing with 444 and D17 when Baler started breaking flywheel shear pins. Timing is good, makes perfect knots an bales (when working). Problem is after tying a bale, needles will fall from retracted position back into bale chamber-causing plunger stop to engage, plunger then contacts stop and breaks shear pin. I believe knotted brake is totally worn - no adjustment left. Agco dealer says obsolete and out of stock. Does anyone know where I may find a knotted brake ( # 543546 ). Or is there something else that should needles in retracted position??? Thanks to all....Dan
tadams(OH) ![]() Orange Level Access ![]() ![]() Joined: 17 Sep 2009 Location: Jeromesville, O Points: 10918 |
You might take the brake off and go to a New Holland or another dealer to see if they will fit.
Tom
Ky.Allis ![]() Orange Level ![]() ![]() Joined: 31 Jan 2010 Location: Kentucky Points: 1030 |
I put new brake pads on my 444 about 15 years ago and they were obsolete then. I took the brake assembly to a clutch rebuilder and he made some brake pads for it and riveted them on. He didn't charge much and it has worked perfect ever since.
Skyhighballoon(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Might be something Rick Corder (aka Rick) here could do as he relines brakes along with doing clutches? PM him. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
orangereborn ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: NW WI Points: 1491 |
Orangereborn 964 192nd Ave New Richmond, WI 54017 715-247-3079 Cell 715-781-2055 |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
You should have a local shop that can add brake lining.
Thanks to all who responded. I followed suggestion and found a heavy truck shop and got brake rebuilt (also included a extra set of linings all for 25 bucks). Also think I found real source of problem. Large castle nut on left end of knotter shaft was loose, causing roller to slip past dog in clutch housing. Due to rain, not able to test it out...but am gaurdedly optimistic...Thanks again (I love to keep the old orange going)...Dan
