Unofficial Allis Homepage
426 vs 301 flywheel
brad durst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad durst Quote  Post ReplyReply Direct Link To This Post Topic: 426 vs 301 flywheel
    Posted: 23 Apr 2020 at 10:09pm
is the crank shaft bolt patter the same one a 301 and a 426? IM not worried about the bellhosing will a 301 fly wheel bolt right on to a 426 thanks
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2020 at 8:51am
Not even close. If you are going to use a 426 in a 301 chassis, you will need a custom built flywheel. Not sure what level of competition you want to run at, but if it is LLSS class I would skip the foreplay and go directly to a 4 X 11 inch clutch. 3 disks won't be enough if it runs hard.
