417 loader /175/WD45 Questions
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Topic: 417 loader /175/WD45 Questions
    Posted: 25 Sep 2020 at 7:43am
Gathering information to make a decision:
Will a 417 loader fit a late 175?
The 1967 417 loader book I have shows it as fitting 170, D-17, and WD45. Is it a good fit or more loader than a WD45 should have, especially front axle assembly?
How much more substantial for loader use is the axle from a wide front 170 vs an early 4 bolt WD 45 Wide front? I can see the mounts are a much heavier, but I'm asking about the axle itself, spindles.
Thanks!
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 9:44am
I'm thinking it's an excellent opportunity to buy a D17 Series 4!Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 10:59am
Could be...if I found one with low hours at the right price that I was willing to take a chance on the transmission/rear end on. That's the best solution. Another alternative is that it could be an opportunity to take a narrow front 1949 WD that probably has less than 1000 hrs on it--but needs engine work-- swap engines with my 170 with the bad gears, add a hydraulic pump/tank to the front, put on power steering and the front axle from the 170, and see how that works with the 417 loader. Correct police hold your tongues: I'm function over originality, and don't view it any different than putting a Gleaner E engine in, or converting a WD to a speed patrol or forklift.
I'm trying to figure out what all my options are before I start spending time and money again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 5:21pm
417 or 517 loader should go right on any 170/175.  The front axle structure on an old D-17 is a little better than a WD45 with 4-bolt front pivot plate. Series 3 and 4 D-17 structure is stronger yet. 170/175 is even more hefty. Spindles are pretty much the same. Any wide front should be fully narrow for max strength.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 5:26pm
Thank you Dr. ! That answers the three biggest questions in the decision.
