38 inch tires on wd45 for pulling
bhalstead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhalstead Quote  Post ReplyReply Direct Link To This Post Topic: 38 inch tires on wd45 for pulling
    Posted: 01 May 2011 at 5:15pm
is there a 8 hole rim that will fit a wd45?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 5:31pm
Any 38 inch wheel from a Massey or a Ford is 8 bolt and will fit an AC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhalstead Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 5:33pm
thank you for the info
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 5:59pm
  have sold some wd45 centers and welded them to 38" rim centers [carefully] with no problems
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 6:12pm
watch out some ford center hole is 5.5 inch no the 6 inch Allis is.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 6:55pm
a massey 65 with 38's use the same pressed wheel center as Allis with 38's.
ac_bowsers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_bowsers Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 7:47pm
Local machine shop here can make you adapters, made some for my D17, eliminates welding plate to wheels. he has saved the pattern in his machine. pm me if interested
Pine Stock Farm "Home of the ALLIS" 35-WC-36-U-37-UC-47-C-49-G-57-D17-58-D17puller-63-D21-71-210puller-79-7045-83-8070-AA9675-BigTen-B10-310-1300fieldcult-snapcoupler imp.-longhopper blower,signs,etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhalstead Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 8:01pm
what do you mean by adapters
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 8:21pm
i have a set of 38' ford 8 bolts for a dual set up with decent rubber on them with the heavy ford dual adapters
i like old tractors of all colors
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 6:22am
There are actually 8 bolt to 9 bolt adapters in the WD45 parts book, but I doubt if there are any available.
