301-426 vs others |
Page <12 |
| Author | ||
7060
Joined: 16 Sep 2009 Location: Missouri Points: 1155 |
Posted: 12 Jul 2016 at 10:07pm |
I know it wouldn't have been likely for Allis to use a cat engine since they were competitors at the time, but I would much prefer a cat over a cummins any day. I'm a little bit of a hater on cummins, but I've never had much luck with them. Cats start way better and the low end torque and lugging recovery would have been a nice substitute for the 3750 series engines.
| Sponsored Links | ||
427435
Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Posted: 12 Jul 2016 at 10:51pm |
There was a lot of bickering by the general managers of the two plants (their bonus money depended on many of the decisions). In the early 80's, they were made to switch places. ![]() |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
427435
Posted: 12 Jul 2016 at 10:57pm |
West Allis basically paid so much per hp regardless of engine displacement. For needed production volume of the 301, a second model beyond the 7000 was wanted by Harvey. I also suspect the 649TI engine was cheaper to build than the 670T engine. |
Mark
427435
Posted: 12 Jul 2016 at 11:02pm |
If by West Allis, you meant the corporate types on the West side of 70th st, then you would be right--------------that's where those decisions got made. However, the West Allis Tractor Plant had little to do with that. |
Mark
427435
Posted: 12 Jul 2016 at 11:08pm |
Not really. The corporation was losing money in areas outside of farm equipment and had big bank loans to pay. The farm equipment was the one entity that they could sell for a good price and pay some of those loans off. Actually, the banks were likely the ones that forced the sale to Deutz. But yes, a modern engine of around 500-550 cu. in. was needed to keep up in the hp race. |
Mark
ACjack
Joined: 13 Sep 2014 Location: Peoria, Arizona Points: 277 |
Posted: 13 Jul 2016 at 9:07am |
The 301 (D2900 series) was "high" volume for the Harvey engine plant. During my years there production would vary from 30 or so on up to 60 per day. That engine was also sold to commercial customers. I do believe you're right about the 649TI was cheaper to produce vs the 670T.
ACjack
Posted: 13 Jul 2016 at 9:10am |
Yes, I was referring to corporate and not the tractor plant.
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 13 Jul 2016 at 10:22am |
JD is not perfect by any means. I just rebuilt an 8.1L in a 7820 tractor because of a piston failure that may have started by a faulty injector. The piston started to come apart above the top ring. The tractor has more than 10,000 hrs but the other five holes showed very little wear. The 8.1L has 1/4" of material above the top ring to aid in better starting an lower emisions. My D-21 has 3/4" above the top ring. I'm told that the current JD engines are using a two peice piston.
Page <12 |
