301 cam shaft removal
d17series4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17series4 Quote  Post ReplyReply Direct Link To This Post Topic: 301 cam shaft removal
    Posted: 08 Jan 2015 at 7:12pm
I am putting a combine engine in my 185. Can someone tell me how to remove the cam shaft. So I can switch front plates. Does the cam gear have to be removed first. Before I can remove the cam. Thanks in advance chad
screwloose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2015 at 8:21pm
No you don't have to remove the cam gear before removing the cam. Don't take the gear off. Turn the engine on at least it's side (preferably farther so the lifters are sure not to drop out). Also I would take the push rods out, it will make it easier to slide the cam out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2015 at 8:26pm
Matter of fact it would be impossible to get the cam out with the push rods in. Behind the cam gear there is a thrust flange with 2 or 3 bolts, take the bolts out.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2015 at 8:29pm
you can remove the rockers, insert / drive in wooden dowels in the lifters raise them up and secure with rubber bands to hold them up.  Also there are at least 3 different front plates.   The early L/M had the mount but no hole.  I used a hole saw - packed the area  with geased rags and drilled a hole for the gear - then the mount bolt that was missing- I used a tab to clamp it rather than a bolt.  Has not leaked or seeped in a few years. Kept from having to swap front plates = welded a predrilled strap to match the side rails.  Also you will have to raise or lower the front axle depend on how you say it, if the 185 did no have a crank driven oil pump - bubble in pan front .
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17series4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2015 at 9:18pm
I do have it on a stand. So rotating it is probably best option. Thanks for everyone's patience. First time I have attempted anything like this.
This page was generated in 0.085 seconds.
