3 Row Corn Head
scott in tenn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott in tenn Quote  Post ReplyReply Direct Link To This Post Topic: 3 Row Corn Head
    Posted: 15 Jul 2012 at 8:09pm
Will a 3 row corn head off of a E3 fit onto a K2. Thanks in advance. Scott
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2012 at 8:38pm
Yes it will fit, the E III has the four push and latch pins top and bottom while the K2 has the newer hook system at the top and the latch pins at the bottom you will need to find the hooks from a newer head. You may have to adjust the drive chain as the K2 drive is wider that the E III
Morley
Farm stuff 8050,6690,175,F2,5050,WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott in tenn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2012 at 9:46pm
I went and looked and the head on the combine now must be a older one because it has the four latches at top and bottom. In that case would it still be better to look for the hocks for the top and if so will they bolt right up or will new holes have to be drilled. Thanks Scott
This page was generated in 0.053 seconds.
