3 bolt wide front.
savedallis1953 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Topic: 3 bolt wide front.
    Posted: 22 Mar 2019 at 6:02pm
First off you gentlemen are great. Thank you for knowledge abundant. I have a 3 bolt wide front and at least one bolt is stripped out. My question is 'is it worth or acceptable practice to drill the bolt holes deeper' and can any internal damage be done by doing so.
1953 WD, 1953 WD, WD engine with WD-45 crankshaft.
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 8:09pm
Have to be careful about drilling in futher can go yo far and get in to oil or grease area I know this will cause problems but maybe helical coils or metric threads just and idea
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 10:26pm
I have one that's drilled and tapped to next larger size..3/4" I think...only on the lower 2 tho...
Edited by Michael V (NM) - 22 Mar 2019 at 10:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 5:09am
Thanks for the information. I now leaning towards 3/4" bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 11:28am
I don't see any reason why you couldn't go all the way thru the casting and tap to the original size. Just so long as the bolt doesn't go far enough to interfere with the moving parts inside.
 A liberal coating of loctite on the bolt when assembling would seal up anything that anted to leak out, or loctite a stud in place and put a nut on the outside.
 Any threaded hole should be at least one and a half times deeper than the bolt size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 5:24pm
even better Idea! W have a shortage of Allis Chalmers here in Florida so the pickings are slim which leads to worn out ones, almost exclusively, if you can locate them at all hence the grinding, drilling, tapping, welding, crying, finger smashing etc. Still love the w series!
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 5:37pm
Drill it out and install a Helicoil insert in the original thread size. You will have stainless steel threads that are much stronger than the cast iron originals.
Edited by Dave (Mid-MI) - 23 Mar 2019 at 5:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 8:42pm
Previous owner had put the 3/4 bolts in the one that I have, its the only one of three that's been messed with. I would have done the heli-coil as Dave said...has been claimed that heli-coil is stronger than the original
