2800 and 2900 Diesel Engine Difference
dhs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dhs Quote  Post ReplyReply Direct Link To This Post Topic: 2800 and 2900 Diesel Engine Difference
    Posted: 31 Oct 2016 at 1:22pm
I have a 1966 190 with a 2800 non turbo engine that has had a recent rebuild. I also have a 1965 190 with a tired 2900 turbo engine. I would like to put the turbo and oil cooler from the 2900 engine  onto the good 2800 engine. It appears that i have all the parts that I will need including the air cleaner. Will I also need to swap the pump and injectors and what other problems should I expect?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 6:41pm
There's something about a slug in an oil passage on the 2800 engine that has to be removed,,,,
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 7:44pm
Compression more than likely will be different, but I don't have the numbers in front of me.
Still in use:
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 7:55pm
The slug is in the 2900 to make oil go around to oil cooler on right side.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:37pm
Compression ratio is the same between 180-185-190-190XTD.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 10:26pm
the tips are a tad larger in the xt,  the pump is set to put out more.  The water pump is located higher on the xt due to volute.  Put the back galley plug in to make the cooler work.
dhs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dhs Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 5:58am
Could you explain "put the back galley plug in" a little better?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 7:08am
There is a plug on left rear corner of block on 2800 block elbow on 2900. Remove elbow on 2900, there will be a long spring, then a plug. Remove and install in 2800 block along with elbow, line, and ect.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 7:10am
When you remove the big oil line elbow at the left rear corner of the block, you'll see a long spring and deep down inside will be a blocking slug. Transfer those parts from one block to the other.
dhs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dhs Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 8:01am
Thanks guys. It's always easier to get some advise before you do something for the first time.
