25000MKII
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Topic: 25000MKII
    Posted: 20 Jun 2016 at 11:46am
What does an industrial AC 25000 MKII engine & radiator weigh?
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 2:55pm
A little over 3000 lbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 5:58pm
Ive just got  actual AC literature on this engine; it says basic engine 3330 lbs; open power unit 3720 lbs,;;;;honestly this engine the biggest piece of cast iron a company has produced in my opinion, everything is cast iron, oil pan , valve covers,, I bought one in Ohio that was used in a nuclear plant as a fire pump stationary supply; it runs great , but cant believe how heavy it is ; id say with the frame and clutch unit , id say close to 5000 lbs ,,,, this one is for indoors as in water cooled exhaust manifold, and set up for an industrial plant,, shes a smooth running engine tho!  I put axles under this frame and gonna take it to shows;its to perfect to tear it apart
Edited by DougG - 20 Jun 2016 at 6:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 8:20pm
Thanks for the great info guys :)
