226 oil system question. |
Post Reply |
danno067
Bronze Level Joined: 29 Jul 2019 Location: Wisconsin Points: 12 |
Posted: 27 May 2020 at 8:34pm |
Guy brought me a 226 motor in a box and asked if could build him a pulling engine for his wd45. After examining everything i believe the block is a d17, the crank is 5.75, the bore is 4.50. Not a bad start. My question is someone installed the cam bearings but the center bearing only has one oil hole that is going to the center main. The main feed passage is blocked. I'm wondering if someone was intending to change the oil system to be priority main oiling. Has anyone done this?
Orange Level Access Joined: 12 Sep 2009 Points: 19560 |
On a "full-flow" oiling system all three cam bearings are the same. On the old cotton string filter system the center cam brg has 2 holes.
D-17 engines have 3 inch main brgs. WD45 mains are smaller at about 2.500" or so.
Edited by DrAllis - 28 May 2020 at 10:20am |
danno067
The block and crank have 3 inch mains. Does the cam serve as the main oil gally?
Hollow camshaft is indeed the main oil galley. That is why it is so important to have good cam bearings for decent oil pressure. Are you a PH8A filter (full flow) or cotton string filter ??
danno067
Judging by the filter base that's in the box of parts i assume it would be a ph8a type of filter.
The cam should be fed oil via the center cam bearing, correct? |
Yes. Then, the front and rear mains receive their oil from the camshaft. Pretty simple design and the block was easier and cheaper to cast without a main oil galley.
danno067
Thank you.
danno067
Dr.Allis one more question. Would know the intake lobe center line for the 175 cam?
I come up with 112.5 degrees for both the 170 and 175 cam which are a different grind from each other. I have a good friend in Ohio who told me trying to alter a 175 cams timing doesn't work well at all. He says A-C has that thing tuned about as well as it can be and still be able to lug down to 900 RPM peak torque. I have never tried anything other than OEM timing for the 175 cam even before he told me that.
danno067
Could you tell me what you think of these specs? Cam specs. @ .050 lift
Ex lobe lift .322 valve lift. .595 duration 239 Ex open 45 bbdc Ex close 14 atdc Ex C.L. 106 In lobe lift .320 valve lift .592 duration 238 In open 9 btdc In close 49 abdc In C.L. 108 Engine specs. 4.560 bore 5.750 stroke Comp. Is 13.5:1 static 1.95 intake valve 1.64 exhaust valve 1.85 rocker ratio Cam was degreed with stock timing gears. Edited by danno067 - 29 May 2020 at 9:23pm |
I have no opinion on the grind. I have used a 175 cam that was ground for more lift. I think it was .460" stock valve lift and it was changed to .560" lift. Timing/duration numbers were to remain the same as OEM. I can't say that it made a huge difference and I simply do not have the time or patience to try five different camshafts looking for that "pot-of-gold" at the end of the camshaft rainbow. This cam was used in stock RPM and 30% over RPM classes. This much I can tell you. I built two identical 360 cube engines 25 yrs ago one winter. Same bore/stroke, camshaft (175) and carb (D-19). The only difference was one had oversized valves (existing customer head freshened up) and the other stock valves with shortened up intake guides. When each was run on the dyno there was no difference in their HP output !! and I would bet the small valve engine would lug a bit lower before stalling. Ignition timing always works best at 18 to 22 degrees BTDC on my engines.
Edited by DrAllis - 29 May 2020 at 9:51pm |
Post Reply | |
