220 pto question
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Topic: 220 pto question
    Posted: 23 Nov 2018 at 10:01pm
I bought a 220 this spring ,  pto It runs all the time and I can't get it to shut off.  When it is put on a pto powered implement it will not pull it.    So is it an adjustment or do I have get into the inards of pto.
Thanks Gerard
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 10:27pm
The PTO lever has 3-positions:  Brake- Neutral-Engaged.  There is no adjustment to the clutch itself. It is 100% a hydraulic clutch and brake. I'd say you'd better pressure test each lever position to verify proper pressures. I'd guess your clutch is smoked and warped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 11:07pm
Thanks Doc    I have a place to start now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 11:09pm
I think the test ports are on the valve itself. I would have had the test ports down at the clutch area, but the Engineers didn't ask me how to do it.
