220 fender head lights |
Kevin210 ![]() Silver Level ![]() Joined: 08 Oct 2018 Location: Indiana Points: 414 |
![]() ![]() ![]() ![]() ![]() Posted: Yesterday at 7:53pm |
Would anyone happen to have a couple
of fender headlights that has the GE letters in the lens,doing a restore and need 2. I got a couple from a website that had a picture of them with GE in the lens but that wasn't what I got. Thanks. |
cdreb ![]() Bronze Level ![]() ![]() Joined: 27 Oct 2009 Location: SE-IA Points: 114 |
I will go check, did have a few of them
B,C,5020,D17,(2)-190XT's,220,D21,7060, Agco LT70
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7451 |
NAPA can cross reference the number. Replace all 4 so they match.
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34249 |
If you have a light with the triangle in the middle of the lense and has a G in the middle of the triangle, that is a GUIDE light... A-C used the Guide light assemblies in the productions of their tractors. Below are a set of lights on a 170 ![]() First light is a 4410 back-up light produced by Guide, lots of fluting in the glass.Was also used as a rear work light. Second light is a GE H7610 halogen 50 watt. If you use these lights, I suggest to either put them on a seperate toggle switch or control them thru relays from the light switch. I smoked a good light switch because I had 3 Halogens on the switch. I put in a toggle switch for them and that has worked very good for me. Third light looks original to the tractor, It is a Guide 4411 35 watt 'utility'. Dealer parts book calls it 'Road headlight', part number 230232 . Forth light surprised me when taking the light out, It turned out to be a GE 35 watt rear tail light/ red light #4409 4tractor6. Parts book labels the sealed beam as #235583 As for the field/work light, think the number on that was 4406. Allis had a part number of 239804 for the sealed beam field light. I would put the larger fluted lights in instead of the multiples, just seamed brighter to me. Years ago I use to have a list of manufactures and number to identify what light would cross over but can't find that list anymore.
Edited by JC-WI - 7 hours 41 minutes ago at 3:48pm |
We are pretty sure these have the number 4406 on them as well.
This what I have and want 2 of the same.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4952 |
I have some NIB GE 4411 lights and a few of then loose.
