200 hydraulic pump. |
clarkscreek
Bronze Level Access
Topic: 200 hydraulic pump.Posted: 22 Sep 2022 at 5:35pm |
Was subsoiling some ground when I started getting sprayed with hydraulic oil. Shut tractor off to check and found the rear housing of the hydraulic pump cracked. All functions are working perfectly before and after. Is this a common problem or is something deeper going on? Also can I get just the rear section?
Mikez
Posted: 22 Sep 2022 at 7:32pm |
What’s the sr number
clarkscreek
Bronze Level Access
Posted: 22 Sep 2022 at 7:42pm |
8818
Albert
Posted: 22 Sep 2022 at 9:19pm |
I have a used pump that I would check out and if it is a good pump I would rebuild and sell. If pump is not a rebuilder I would sell the rear housing providing it was good. Please call after 5PM or text anytime Albert 660 541 2029
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8982 |
Posted: 23 Sep 2022 at 8:35am |
Be sure to check relief pressure before busting another hsg. Only thing I know that would crack hsg.
clarkscreek
Bronze Level Access
Posted: 23 Sep 2022 at 8:43am |
So after taking the pump off I found where the previous owner had jb welded along the crack on the back side. This cracked extends from the secondary to primary ports. Only pressure I have ever checked on tractor was remote pressure, and that's only because my trail mower uses hydraulic pressure to float the cutter bar. That pressure was right at 1950 to 2000. When I get it back together how do I go about checking and adjusting relief pressure?
Posted: 23 Sep 2022 at 9:30am |
This trail mower requires you to lock-in a remote lever and maintain a constant 2,000 psi of pressure to it ?? That won't work on a 200.
clarkscreek
Bronze Level Access
Posted: 23 Sep 2022 at 9:56am |
No that's just to charge system on mower. After that while your running its just up down like normal.
