200 hydraulic pump?
acplowboy45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Topic: 200 hydraulic pump?
    Posted: 18 May 2018 at 8:29pm
Ok I have completely rebuilt my pump new Orings,wear plates, new filter and fluids and then on top of that had to replace the oil cooler out front. Question is why is my power steering so hard to turn for and why is my pump getting really HOT!!! Now to answer and ? Yes I took the spool out and polished it really good.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2018 at 9:53pm
Did you get the seals pushed down in groves good? Did it turn free after assembly? Did you torque the bolts even as you went around? Does it get hot without hydraulic load? Did the steering work good before the rebuild? Why did you rebuild the pump?      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 4:40am
We rebuilt the pump because I lost all hydraulics while dicsing NO steering, no 3 arms would lift., That found blue Teflon in spool spring while I was cleaning it. Yes it gets hot when it not even under a load. Yes all seals we're correctly put in right and too it turn freely. Also we torqued all bolts evenly.
Edited by acplowboy45 - 19 May 2018 at 4:42am
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 8:31am
Check to see if you have those blue pieces in you relief valve too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 11:55am
Is the releif valve inside the pump or behind one of those caps on the back side of the pump.
