200 front tires
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 200 front tires
    Posted: 03 Jan 2016 at 3:19pm
What's everybody running for front tires on your 200,
The 200 we have came with 11-L-15 implement tires on it. Was going to put new tires, like maybe three rib. Just wondering what others are using.
Thanks
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 3:59pm
I use the same as yours--11L-15 which is what came on it new. Mine are 4 rib and I really like them. I would not use 3 rib design with the center rib taller. Turn sharp and you will plow up the grass in your hay fields.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 5:03pm
10.00x16 tri rib on my 190xt
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 5:04pm
all of the ones around here have 10.00x16
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 5:06pm
I have seen 11lx15 and 1000x16's on them. Mine has 11Lx15's 4 rib on it. If you have a loader be sure to get some 8 ply. They don't turn as well as the 3 ribs, but I think if I ever get the weights put the front of it--it will be a lot better.
Plowjock5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Plowjock5 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 5:21pm
I have 11Lx 15 four rib on mine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 6:17pm
Any of you have picture of the 4 rib. Thanks
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 6:34pm
Dad's had 10.00 x 16 first 3 rib then 4 rib. We like the 3 rib better for turning. My 190 has 11L x 15 for rib. My brother's XT ??????????? don't remember except they are 15 inch.
Wink
I am a Russian Bot
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 7:01pm
20 x 7.50
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 10:30pm
put airplane tires on it!
This page was generated in 0.246 seconds.
